Fallout 3
Publisher: Bethesda
Fallout 3 is the revival of Interplay’s excellent
Fallout series of games following many years out of the limelight. It’s developed and published by Bethesda and, judging by the success of the game, we’ll be seeing more
Fallout games in the future.
Despite using the
Oblivion engine which is now a few years old, the game looks absolutely stunning. Bethesda has spiced up the graphics a bit since
Oblivion and has extended the engine – there are some great explosions, soft shadows and smoke effects that are particularly noteworthy.
We tested the game by manually playing a section of the game that incorporates a number of explosions and effects that you’re likely to experience during your time in post-apocalyptic Washington DC. We recorded the frame rate using FRAPS.
The in-game details were set to their highest values and both anti-aliasing and anisotropic filtering were controlled by the application settings instead of through the driver control panel. This meant that transparency anti-aliasing was enabled, along with HDR and all of the cool smoke effects.
Fallout 3’s engine is by default capped to 60 frames per second, which can make benchmark results very unclear, especially when testing at lower resolutions or with high end graphics cards. To remove the 60FPS cap you’ll need to find the Fallout3.ini file in \Documents\My Games\Fallout3 and edit the file so that iPresentInterval=0. This removes the frame rate cap, and allows us to get a much better idea of a card’s abilities.
ATI Radeon HD 4850 512MB
ATI Radeon HD 4830 512MB
Nvidia Geforce 9800GT 512MB
Nvidia Geforce 9600GT 512MB
Nvidia Geforce 9600GSO 512MB
HIS ATI Radeon HD 4670 IceQ 512MB
ATI Radeon HD 4670 512MB
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
We know from experiance that
Fallout 3 is a very memory bandwidth hungry title, but even here the slight increase in memroy clock of the HIS Radeon 4670 IceQ over a stock 4670 isn't at all apparent. What is interetsing though is just how capable all the mid range cards we tested were in
Fallout 3, even with the game set to Ultra detail level and rendered using 16x anisotropic filtering. However, other than the stock clocked 9600 GSO, the 4670 is still a ways off the similarly priced 9600 GT, especially at 1,680 x 1,050 where the Nvidia card is almost 50 percent faster!
